Hi guys,
I just got in the new/used set of rod bearings that I need to fix the F-20 I recently got. I have done rod bearings before, but the thing with this tractor is there is rust on the crank since two sets were removed when they spun.
Question 1, whats a good way to clean the crank/get it nice and shiny again so I can install the new bearings? I think someone mentioned Emery cloth would work to get rust off without scratching the crank? I just can remember if that's the right name of it.
Question 2, what are the torque specs for the rod bearings?
Also what is the measurement for plastiguage (i think that's what its called)? I've never used it before when putting in rod bearings and haven't had any problems, but since bearings for this tractor are hard to come by I just want to double check. If anyone can explain how to best use it/what size to get too that would be great.
Any other advice/things to look for and check are always greatly appreciated
Thanks,
~FarmallCT
Thanks,
~FarmallCT
