I purchased a 12 volt conversion from
Yesterday's Tractor and I want to put a volt
meter on instead of an amp meter. What's the
best way to do this? I have a distributor. I
would like to use the wiring harness that
came with the kit and not have to butcher it
up. They make a very nice wire harness. The
harness has a wire that runs from the
alternator to the amp meter then another one
that runs from the amp meter to the starter.
Can I put these two together on the + side
of the volt meter and then ground the -
side? Or is that going to drain my battery?
Thanks,
Jeff
Thanks,
Jeff
