T in NE
- Location
- Cambridge, Nebraska
First, what is the pattern on the range selector?
Second, the front two positions on the range selector, don't engage. When you let out the clutch, the lever moves back about a half inch. Could the cab mounts be bad causing this? Any chance the linkage could be adjusted to get those two ranges back? Or are chances better of those two ranges being toast??
