farmall 300 row crop engine bolt location
dewy
where are the bolts and how many..manual just says support tractor under clutch housing.unbolt bolster from frame rails and remove bolster....attach hoist to engine,remove frame rails ..unbolt engine from clutch housing and remove engine.......i dont see where it bolts to housing...they show no pics.......how many and locations,,,,what am i missing........thanks in advance........dewy
The only screws from the front are the four on each side that go through the rail. There are two from the back at top of clutch housing into back of block.
You may find one in the starter hole. as well as the two on top from the rear going forward, and the frame rail bolts.. The dowels are often tough to set started toward separation. Jim
