IH 504 Shifter Problems
keithre
I have a 1966 IH 504 Diesel and lately its getting harder and harder to shift between 1rst & reverse or 2nd and reverse. Clutch is good, just really hard to shift. Any idea's ??
If it has a T/A, the T/A clutch is out of adjustment and not disengaging quick enough. The two clutches need to disengage correctly or you get hard shifting.
Roger
(quoted from post at 03:16:57 10/16/16) If it has a T/A, the T/A clutch is out of adjustment and not disengaging quick enough. The two clutches need to disengage correctly or you get hard shifting.
Roger
I agree. That is exactly what happens to my 504 gas when the T/A needs adjustment.
The next time it does that, shift the T/A, If it shifts fine then you know it is time to adjust the clutch and the T/A. Get the book, because it seems every model has a different adjustment procedure.
