Super c with woods mower questions
Yodie
New User
I just purchased a 1952 super c with a woods mower on it. I want to get a fast hitch for it. Is it possible to get a fast hitch set up and still keep my mower on it also? Currency my mower is lifted my themail hydraulics.
Off the pto.
Could I get an after market 3 pt and still be able to keep it on at the same time?
No, there is not enough room for a Woods belly mower and a rear hitch. Yes you could add an after market 3 point hitch, and then use a rear 3 point hitch mower. I have had or do have, belly mowers,3 point mowers and fast hitch on different Super Cs. IMO, tractors with finish mowers are way too much trouble,I can mow circles around one with a good 60" deck and a 25hp motor. I do like my Super Cs.
I have the mounts that use the belt pulley but any belt pulley will be in the way of fast hitch or 3pt. I f you look at your mount for the mower you will se a 3pt and fast hitch will not work with the mower so the answer to your question the 3pt and fast hitch are out of the question.
Trying to upload a picture of my set up
yours drives off the belt pulley i would think a fast hitch would work it sure would be worth a try cause the fast hitch is great.
The pulley mite be in the way cause even the standard belt oulley will stop fast hitch from raising all the way up but it still would be worth a try. IT would stop from raising fast hitch all the way up. But if you are just going to use fast hitch for blade removing snow the pulley could be removed. Now you can use a regular blade fasten lower part to drawbar and use rod from lift assy on rocker assy back to blade to lift blade dont need to have fast Hitch to use blade on a C. I use a 3pt blade on my B hy pump running of pto bolt the ears to the drawbar with a bracket i made then use a 2 way cycl just on the lift side as third link to pic up blade works just fine been using for many yrs that way. I could have it 2 way but all you do is ift back of tractor up with down pressure.
