Belly blade mount under fast hitch 140
Teamja2
New User
Does anyone have diagrams or pictures of how a grader blade mounts under a fast hitch 140? I have a substitute draw bar from a super a that may work once the fast hitch is removed but suspect there may be an easier way.
Have to take off the whole lower rear fast hitch, then you can mount the grader blade. Easy to do, remove 2 rear top pins on fast hitch, then remove front pin
on lower yoke , then put lower yoke in the "keeper" under the floorboard. Should take you about 10 minutes.
I tried the mid mount grader blade, didn't like it, if you need down pressure it lifts the rear wheels up off the ground. I use the blade mounted in the front
as a grader blade.
Have fun.
Forgot to mention the mounting piece for the grader blade. It is a u-shaped piece of flat stock, about 1/2 inch thick by 3 or 4 inches. bolts to the big bolts on the
bull gear housings. Then the plow mount bolts to that.
