new disk blades
bass
here is a photo of Mable and Brownwood. I am gonna have to put new blades on Brownwood.
when measuring the disk diameter on notched blades, do you measure from the out side of the notch or from the gullet?
second, are the front blades and the rear blades the same diameter.
bass
53superC
Also, realize that the blades will be worn about 1/2 to 1 inch shorter than original. The supplier should be able to use your actual measurement to surmize the original length / size.
I would use 20" smooth blades on that disc as I don't like
notched blades because they always make clods and won't
finish.
