international 574 stuck in 2 gears
macs
New User
Gday, was doing some grading on my international 574 in 4th gear low range, when it jumped out of
gear and stalled.Now the only gear i can get it to work in is 1st gear but the range
lever(high,low,neutral and reverse) works perfectly.Would really appreciate any input and advice on
the problem.
cheers
You need to get into the shift linkage area below/behind the sheet metal. Then, by manipulating the shift linkage, get both range and speed shifters into neutral. Then you should be able to shift into and out of any gear with the levers. It will probably be OK then for a while.
