What do they grind first
But like Pete 23 was saying, one 806 crankshaft was so bad the timing mark was off,so after they had it centered, it must of slipped some how, but either way the machine shop, should of been liable !
I always did the rods 1st as when the mains were done the whole thing was polished with a fine sanding belt.
Ok, I seen only one crank grinding machine, it been a long time ago, and never has to send one in. Thanks
In the factory, the mains are ground first, then the the pins. The #1 pin is usually the datum for index on the pins. The pins are rough machined
to a index hole located on the flange. But the hole is located from the #1 pin to start with. The index hole is one of the first operations in the
process.
