Prong size for single point hitch - Cub vs A
denglish
Are the prong sizes the same for single point fast hitch on an A versus on a Cub? I have an A with single point and sometimes see single point implements listed for the Cub on the internet.
(quoted from post at 10:53:36 10/04/16) Yes. Both use the same large prong as is used on the 300/400 size tractors. Just one instead of two.
Thanks, I'm wondering if this plow will work with my super A.
https://www.purplewave.com/auction/161026A/item/BV9893
a cub plow will work on s a. but will not go in ground very deep as the beam is shorter than a s a plow the cub plow should have cub name in beam.
(quoted from post at 18:45:43 10/04/16) a cub plow will work on s a. but will not go in ground very deep as the beam is shorter than a s a plow the cub plow should have cub name in beam.
Thanks!
