FarmallMOwner1
New User
I'm new to the forum, so my appologies if I don't follow proper ediquite. I recently bought a house which came with an old Farmall M (year unkown?). Apparently the previous owner didn't want to be hassled with moving the tractor. This farmall has sat out in a field through all of Michigan's seasons for the last 20 years. It's covered in rust and in very bad shape. It fired up every time without any problems, but it would overheat after about 5 minutes. I wanted to start working on the tractor, so I moved it to my barn. While moving it, I noticed there was a fuel leak from the sediment cup.
I ordered a new sediment cup and decided to clean the Zenith carburator while I waited for the sediment cup to come. Yesterday I put the carburator back together, installed the new sediment cup, and tried to start it. To my surprise, the tractor wouldn't even turn over. When I pressed the starter, it would give one good attempt ot turn over. The fan would turn about 1/8 of a revolution, but then it would just stop.
Did I do something wrong while rebuilding the carburetor? I would imagine that it would still turn over, but it wouldn't fire up if I messed the carb up.
Any help is appreciated.
