Thanks Pete;
I looked for dings and any imperfections. I thought I'd see some, what with all the handling I had to do to work on the spool. None were visible, though I burnished the front end of the spool a bit.
I finally decided to just take a risk and do something I NEVER think of doing with finely machined parts: I just got a big BFH and gently rapped it in. Once in, it seemed OK. For some reason, it just fits tight at the first part of the insertion.
I fired the old beast up, and everything works.
SOOOOOoooooOOOOO, thanks to all who helped me, for your advice, knowledge, and patience. Everything works, and so far as I know nothing leaks. For now... it's been a long slog:
hydraulic leaks
broken hydraulic lines
plugged hydraulic filter
random broken parts in hydraulic filter cavity (EGAD!)
leaky gas tank
gummed up carburetor
bad/missing exhaust gasket
aux lines welded in really bad position
aux valves of mixed type and assembled incorrectly by someone before me
leaky valve cover gasket
probably a few things I forgot, deliberately, and when I started I knew nothing about tractors.
Anyway, the Old Beast is almost ready for winter snow. Just a couple trivial things to do.
Thanks again to EVERYONE for all the help on this website.
And don't worry, you've probably not heard the last of me yet.
Jimo
hydraulic leaks
leaky gas tank
Jimo
