Farmall m 2 way hydraulic valve
johninmn
My m has the 2 way hydraulic valve but no lever or linkage. Anyone have a picture i can see? Searching isnt helping
(quoted from post at 19:47:10 09/28/16) My m has the 2 way hydraulic valve but no lever or linkage. Anyone have a picture i can see? Searching isnt helping
Go to case-ih and look at the drawings
Yeah, i have. Thats why I'm asking here. I
just wanted a picture of thr linkage for the
2 way valce so i can try to rig something up
on mine
(quoted from post at 03:02:44 09/29/16)
Why not just get right parts
Because the parts aren't available and it's just a simple straight rod running from the valve up to a guide mounted on the light bar.
All you need is a piece of 3/8" round bar. Bend a 90 degree in one end for the valve, and either forge a loop on the other end or thread it for a knob.
You didn't say if it's a valve like IH used and is the double acting valve or unit in center housing missing a lever or both? or none?
On my M, I wanted more precise control over the sickle bar on a mower so I fabricated a bracket and mounted a single lever valve next to the right headlight. I welded an extra lug on the pull rod to keep the pump engaged full time and circulate the oil though the remote control valve.
Sometimes, like on a sickle bar, you want to just nudge the bar up or down an inch or two and you don't have that precise control with the pull rod.
(quoted from post at 07:56:18 09/29/16)
Must be a local thing.........I see them at salvage yards, on flea pay etc.
Surely you can make up a new rod, holder, springs etc.
