There are 15 notches for use by the governor control lever on my Super A.
When lever is in notch 1-4 there is no noticeable difference in engine rpm. Simply at idle speed.
Notches 5-11 are "useable" and noticeable change in rpm when moving thru these notches.
Notches 12-15 cannot be "reached" by the lever - it just will not go that far forward.
As expected, I can use my hand to manually manipulate the governor connecting rod to carb and get increased rpm.
Carb is a new one I purchased from Yesterday's Tractor as I recall.
My concern is no noticeable change in notches 1-4 and unable to use notch 12-15 for faster rpm.
And your solutions are??????
Thanks.
Thanks.
