Farmall Super M6
centash
One of one? Ben
(quoted from post at 03:58:47 09/24/16) One of one? Ben
I saw it at the IPM also. It belongs to a Chapter 20 member. It was skillfully done with I think a 706 engine and side frames. No cutting and welding that way. It looks like that whoever lengthened the hood must have been a highly skilled welder and possibly used a TIG setup to do the welding. The only indication of not being original was the water pump to lower radiator tank connection. The engine outlet is on the left and the rad connection is on the right and so a crossover pipe was necessary. It looks like what a disguised 560 prototype might have looked like. I saw another 6 cylinder conversion at Red Power Roundup in 2014 in Ohio that looked similar.
A very good friend has one and calls his a M60 since the engine is out of a 560. And he drove m60 tanks in the army. That dude will get up and haula$$. Only trouble he hs had with it they tried plowing with it and she overheated. Even has a electric fanon the radiator......Kenny
