SMTA needed a bath so pressure washed it. Of course it wouldn't run right as I got some water in the distributor. Cleaned it all up and still didn't run right. Well distributor cap looked kinda dark in one hole maybe needs a new one, off to NAPA. New cap an wires back in still doesn't run right. Spark plug wires kinda old, maybe I need a new set, back to NAPA. wires changed and now it won't start. since I am working on ignition must be a problem there, no ran out of gas. Now it is flooded so let it sit a while. Starts but not running right, hear a pop in air cleaner, maybe Electronic Ignition is going bad, but try another rotor(not new). Bet my bent wrench out to change timing on distributor then think again. Maybe the distributor shaft doesn't turn the way I thought. switch wires on 2 and 3 and wow, now it runs perfect. Didn't mention I swapped out 2 plugs in there also. Think it needed cap and wires anyway, only money and time I guess
