IH 350 Wheatland
molinegb
How many 350 Wheatland Specials were made? Have a 1957 350 gas model with T/A. It has battery under steering column. Has extra gas tank behind seat. All original with new rubber. All tin and chrome in good shape. What would one be worth 3K?
There is a lever in front of where oil filler cap is. What is it for?
I do not know the numbers, but I think it is rather rare. Assuming it has no fast hitch, and does have Power steering, 3K sounds reasonable. Jim
A extra gas tank behind the seat, i guess thats a new one to me,but haven't been around that many wheatland tractors. But the lever in front, that on the right side, correct, could that be a pivot point for the shutters, that maybe it once had?
Gas tank is factory and plumbed into sediment bowl. Also was thinking lever was for shutters.Maybe an option.
I have a 350 wheatland special as well with the auxiliary fuel tank, looks like factory installed. Definitely has shutters as did most of the tractors that came here ( north central Alberta ) as I understand it the Canadian versions was Wheatland Special, the US version was Utility. Mine even has the hood holes for the utility emblem. Nice tractor, only drawback is no 3pt. hitch.
I have also heard of a "High Utility" version. Not sure if that is the same as the Wheatland!
