IA Roy
Did these tractors have a transmission brake to bring the shafts to a stop to prevent grinding them into gear? From the knowledge I have acquired since I ran one, I wonder if the ones we had were out of adjustment or if there just were none in the design.
Please tell me more! My 706 does grind a bit, though I don't force things. I know of only a "parking brake" that locks the transmission, but things have to be stopped to use that, or so I thought. I'm looking at the manual. Where is this other brake?
Thanks,
JimO
It will HELP SLOW the gears down but it will not stop them in a instant For best results idle the engine down before you push the clutch down and just wait to make the shift. If you look back thru the archives under clutch , T/A dump valve adjustment i have layed out how to do all of this the easy way .
Jimmy
Attached picture above shows transmission brake location ( red arrow) New ones are available from several aftermarket sources. Not difficult to replace.
Contact me for recommendation for supplier source.
Weldon;
Sorry for my slow response; I was out of town.
Thanks for the info. I can't get to that kind of thing until next year. But I will save your comment and reference. I would not have known that the parts you highlighted did what they apparently do. I'm almost done working on hydraulic leaks, and winter is nigh. I won't be taking anything apart until after snowblower season!!!
Thanks again,
JimO
