Dieseltech
- Location
- Akron, Indiana
Need some advice on a late D-282 block from a 656 I have, SN 82391. Block is stripped down except for pulling the sleeves. Repair manual and parts list shows sleeves are coded S-1, S-2, and S-3, but I have not found any such code stamp on the block yet. What it does have stamped on the deck is the letter L next to cylinders 1,2,3,4, and 6. Letter H is next to #5. Pistons have the same stamped letters too. Where would the S code be stamped if it has one? Also wonder if the coding is critical, any aftermarket sleeve sets only list one size. Can these be pulled with a manual sleeve puller, or should I get the air over hydraulic puller a friend has that I've used in the past? The last Perkins dry sleeves were a bear to do by hand, but the hydraulic one made short work of the job. Thanks in advance.
