W-400 Chris
Hello there fellas, I just recently bought a 560 Farmall Diesel. It wasn't running when I bought it but tin was good and rubber was good so I thought I would gamble on it, only paid $1000 for it so didn't think it was too bad might be crazy but theres not many Farmalls in my neck of the woods anyway. The problem I'm having is that the injection pump does is not pumping any fuel to the injectors. I have fuel to the injection pump and I pulled that screen on the injection pump inlet. The hand primer before the filters pressures up that rubber hose very well and I changed the hose also between injection pump and fuel filters and when I pump the primer pump fuel comes out very good. I'm looking for some expertise on this problem and figured this is the best place to look. Thank you in advance. Chris
