Cleaned up generator commuter and got my system charging again.
Decided to remove starter connections to clean. Switch stud ended up spinning. Took apart and cleaned up copper, tried using a double nut to fix stud. Reassembled and starter would barely turn over. Rechecked connections and tried again. Same with little smoke from starter cable (0 ga). Connection at starter got warm and ground-to-frame connection. Switch contacts seem to be getting good contact. Starter copper post is dented from use. Got a tractor supply switch, installed, and barely cranks with some more smoke. So didn't crank it long. Sounds like a computer case fan running. Tested battery voltage and is 6.15 v.
[b:c8cc4466c6]Is my starter toast[/b:c8cc4466c6]? Before I messed with starter it would start. Sometimes slow and be a pain, but battery wasn't getting charged. I've been charging batt before use usually.
