wiring harnesses
What wiring harness original or did someone over the yrs change it You cant hook up the original wrong unless you dont have a wiring dia thats in the owners manual. Does your tractor have the original cut-out or has it been changed to a regulator too many things need answered as aftermarket harnesses are all different when it comes to color of a wire.
I want to do the wiring harnesses myself and I want to know what the colors of each wire so I can order the wire so I can build the harnesses like the one came on the tractor , I'm use to working with wiring dia with the colors and tracer colors , wire size .
