mountain4don
I was having trouble with the magneto on my 1954 Farmall Super C tractor not working when the engine was hot. About 10 years ago my Farmall M ignition quit, so I borrowed the battery ignition off my Super C. So now I am returning the battery ignition to the Super C. I have it all mounted and it runs good when I jump power to it from the terminal on the starter. I pulled the battery box out and the ignition switch from the panel, and one side was connected to the wire from the magneto, and the other side just grounded, to serve as a short to turn the magneto off. So now I want to connect that same wire for the battery ignition and don't know where it was originally connected. I have a "Super C Tractor Operator's Manual", but the wiring diagram is hard to see. Does the "L" wire from the regulator (wire 28) come up and feed both the power terminal on the ignition switch and the fuse holder (wire 33) for the lights?
