As a complete new person to setting up a plow, what should the left rear wheel be set at for plowing with a #8 14" plow? Also I will use it on a 300 with 2 point hitch and the 2 point draw bar. Where should I place the clevis and how high off the ground would you set the draw bar?
As a kid, Dad had a small stick we used to measure between the axle housing and the wheel. I never did ask or find out what setting that was. And he just knew where to put the clevis on our H's solid draw bar that we used to plow with. They of course had the solid draw bar with the swinging one.
