140 farmall generator
khouse6
tag is gone from generator. would like brush set. would the generator, more than likely, be a delco?
the brush set that i can find (for delco) looks correct.
Clean the slots on the comutator then sand smooth and be sure to turn the new brushes the correct way so they can seat if wrong only the pointed end will make contac. polorize gen before starting engine. Pos gnd.
