Farmall 350 newbie
nytfr8
New User
Good afternoon, I just picked up a 57 350. My question is in regards
to the PTO, the PTO will vent over through the breather tube cap hole
when it is not active. I've drained the old fluid and replaced with new
hytran fluid. I followed a few videos I have found to adjust it, it seems
to be functioning properly just over venting. The fluid that does come
out looks like it possibly has water in it or aerated, milky looking.
Thanks in advance for any help that anyone is willing to give.
There is a seal between pto housing and main trsnsmission case. You can pull pto and replace but chances are shaft has slight groove. On my Super MTA took off breather, put in elbow with hose barb, ran fuel hose up to check plug where I replaced plug with tee. I know it would be ticketed by the correct police.
