i found the problem with my mag
bass
after reading all of your responses and a you tube video on rebuilding a magneto, i found the problem: the wire from the points to the condenser i think was grounding out. its an original IH part. it took the mag off, cleaned it up, then started to disassemble. i found the wire was grounding. i added a little black tape then reassembled. put the mag back on found i was 180deg out, to took the mag off and realigned it. reassembled everything, and Molly started right up.
thanks for all the help
bass
53superC
good to hear, as that was my first thought when u said you had no spark after replacing points.
i wish we had more feed back on fixes.
