Two cycle oil after head rebuild.
Someone on here suggested running some two cycle oil after the head rebuild. That sounds like a good idea, dad used to run some MMO in the gas tank from time to time. My old boss used to put motor oil in gas tank of small Briggs motors. So would a pint of two cycle for ten gallons be good? That will be about 80 to 1 ratio.
Thanks everyone.
Don't know what you are working on . If a tractor put in the oil you will run in it and don't baby it. The best 450 I ever new was the demo that had
4/16s behind it for a lot of plowing.
Sorry AceS, yes it's my gas 450. I had the head rebuilt with a new valve train, valves, guides, seats, the works. I've replaced all the usual tune up parts. I have a 4-16 plow and it's going to be used plowing and using a box blade. No parades or tractor rides in her future.
