Help Identify PTO Pulley
RTR
Does this pulley fit an Allis Chalmers or a Farmall? I bought it at a sale where there were some Allis Chalmers G tractors and some Farmall Super A and Cub tractors. I don't see many markings on the pulley. Just trying to figure out what it is for.
Barn. Eng. is correct, Unless the msnglrd splines are just the very edge, and 80% of the splines are fine and dandy, it is only good for machining out to a bigger size
and using for something else. Jim
Besides the GUESSES it may be for a Cub there's a WIDE variety of machines it may be from.
IH used all sorts of sheaves like that with other that 6 or 21 splines like standard PTO's on mowers, windrowers, probably combine heads, and likely other machines, as well.
(quoted from post at 07:26:11 09/07/16) Besides the GUESSES it may be for a Cub there's a WIDE variety of machines it may be from.
Except it has TEN splines.
The Cub PTO is pretty unique in the IH world having TEN splines, and coming from a place that had Cubs, it's a pretty sure bet.
(quoted from post at 22:05:43 09/07/16)
I wonder if that is a pulley like used on the 42 inch belly mowers (woods, danco/IH, etc) or was it on a Cub implement like a sickle mower? Just curious as it looks different than most pulleys used on a Cub. The splines aren't totally stripped so I figured it could still be used some more.
