Larry Heckman
New User
I'm having a problem that just started last week. I can start and run my Super A for about 10 minutes and then it starts to act like its starving for fuel. It starts to surge and buck. It seems to only continue to happen under a load. When I push in the clutch it seems to recover and will idle normally. I noticed there appears to be gas leaking through what appears to be a weep hole in the bottom of the Marvel Schebler carb when it isn't running. Do i have some junk in the carb? Maybe a rebuild? This tractor has run flawlessly since i've had it, almost 2 years. Don't have much experience with carburators. Any help would be appreciated.
