656D with 282...The oil capacity with filter is 9 quarts by the book. If you change the filter you add nine quarts, run the engine check the oil and it is within limits (full). If you let it sit and go back the dipstick will show it 1 quart overfilled. When looking at the owners manual I see that the gas model of this tractor has a check valve in the filter housing to prevent the oil from draining out of the filter and back to the crankcase. The diesel version show no check valve. I talked to an "old" tractor guy (like me...ha ha ha) that said this is normal??? He said some old tractors use to have a dipstick that had two full lines, one for use after sitting and one for after just running?? I am curious to know more about this?? I know that some old tractors did not have a dipstick at all but rather a "petcock" you opened to see if the oil was full??? IF the oil filter is allowed to drain back as I am seeing it would seem that it would take a longer than necessary on a cold start to get the oil where it is needed?? Seems as though this would shorten the life of the engine?? I am very curious to hear any input on all of this. Thanks
