Zenith carb 11007?
Lucid
I have a spare carb I cleaned up and put on my tractor while I fixed the current ones stripped drain plug. This on looks to have 11007 stamped where the tag should be. The drain plug on this is straight out the front, not the bottom. The intake tube is a little larger than the original. Measured 1 3/8 ID with 1 5/8 OD. Closest one in my book is a 68x7, but with drain plug on bottom. Could this be for an H instead of my 200?
Several engines larger or newer than the 200, but in the same basic format, have different carbs, these include power units and combines. Jim
