cub would not run. began checking. 1 points, coil wire, etc etc. came down it had to be rotor button or distributor cap. the little towers on the
distributor cap were corroded bad. really bad. i tore off a strip of emery cloth, rolled it up and cleaned the inside of them. tractor started. do
you have a slick trick for cleaning the contacts (where the spark plug wires plug in) inside the distributor cap.
