Two problems:
1. New regulator and rebuilt generator but with the tractor running, always a negative discharge. How can I simply check generator output with
my volt meter.
2. Big problem...new head gasket. Head and block looked flat, clean and no evidence of cracks. Cleaned everything well, carefully torqued down
the bolts and antifreeze leaking into oil! Ran it several times to heat up and cool down, retorqued and still leaking ?????
my volt meter.
