International Harvester Model A470001B002196
KYBOB
New User
I need the tie rod ends and the series number. This is supposed to have been built in England and be
a 434 but the ends don't match the ones on the tractor.
The tag on the side says built in England and Model A470001B002196. But I can't get a hit on that
number???
HELP
I have an english built 238 industrial can't fine anything on it, But in AG tractor it is a IH 384. If you can fine what AG model that match it you should fine parts around.
You may have to check with a case IH dealer to cross that #
A470001B002196 is the serial number of the tractor, not the model number.
The problem is you're working on a 40+ year old tractor and many things may have been done to it over the years, and many changes have been made to the parts over the years.
While the tie rod ends you bought may not look the same, what's important is that they FIT. Have you tried to install them?
The tag said model number. I just found out that is the serial # today.
The tractor is a B515 , thanks for the responce.
BOB
