WI International 350
New User
Looking for some help on where to go next. I'm new to owning my 350U and ran into an issues where it wouldn't start. After testing the spark, I learned that my points were bad. In the process of that (not knowing the points send the signal to the coil for spark) I turned the motor over so many times trying different things that it seems that it is so flooded that I have oil shooting out of the top of the air cleaner. I took the tube from the air cleaner that runs to the carb off, drained that out, but still am running into the same problem. I took all the plugs out and turned the motor over trying to help dry things out as well. Looking for other suggestions on curing the problem. Any help would be much appreciated.
