Hello All!...just purchased a B275 as my first tractor and first job was to clean out the fuel system and change fuel filter however, when searching for the filter it appears there are several listed for the B275 including a metal canister type and a paper type.
Tractor is an early 1960 model with a metal CAV filter bowl and a vertical shaft that runs through the centre. The current filter inside does not need seem to fit and moves appears to up and down when its all assembled and the spring at the bottom of the shaft appears to do nothing. I'll try to post some pics of the current setup....
