I have a 1952 Farmall H and I'm trying to figure out which light switch I need. From what I can tell from doing some research online and by what external link tells you, if you have a 6V voltage regulator, then you need the switch that doesn't have the fuse that snaps in the back and then you have the separate fuse holder.
If that is the case, then I have a mis-match (see pictures). When I got my tractor after my grandfather passed, the lights didn't work. I have the rear lights working and I recently connected the front lights and things got hot and smelled like plastic was cooking. I have a guess that my grandpa may have installed the wrong switch at some point and just wired it to make it work. I'd like to get a new fuse holder (and wires, they are bare) and a new switch.
[b:432262b127][i:432262b127]Can anyone confirm my belief that I need the 3 position switch for a 6V regulator?[/b:432262b127][/i:432262b127]
http://www.external_link/IHS595-6-volt-rotary-light-switch-3position?&TF=882F1A2123AC
