Had some issues with my 200 running. Was getting hard to start, so I cleaned the plugs. Then checked the points. My points were ok, but my rotor arm was ate up. I have never replaced points due to pitting/worn. Will have to replace the rotor here and there.
Is there something causing this to the rotor arm? Or is this normal wear? See pic.
Also, after I got everything cleaned up, I started the tractor. Ran like crap. Thought I may have not seated one of the plugs good. So I put my hand near the plugs to see if I could feel air coming out. Got about 10" from the wires and got a good shock! Would that be bad wires? Ended up a wire was shorting out on the block through insulation.
[/img]
Thanks
Thanks
