Bull PinionBreak Shaft Bearing
jimdog
Replacing o-rings and seals in the brakes on my 826 Farmall. Found on the right side the bearing on the bull pinion brake shaft is bad,rollers all there but chewed up.Any ideas what may have caused this? Can I replace this bearing in place? Or does the axle housing need to come off. This is a gear trans.
Thanks for any help.
should be able to replace by pulling the brake drum I believe. Others can give better information there. It has been a while since I have had one off. The bearing probably just got tired. Or ran low on oil. As the hyd and trans share oil reservoirs.
