My 1940 A sat over a winter, then for no reason, only runs at full rpm unless I hold rod from governor to carb ahead. It has a new spring (
years back I rebuilt everything)in the housing, bearing looks ok, has good spring tension not running (between levers), weights move
freely,and not sure where else to look. I have service manual and have rebuilt some before so I have some experience with them but just
replacing springs, bearings, etc. It has sat about 5 years now since the problem started and finally trying to fix it so I can run it. Any
thoughts will be appreciated.
