hydraulic oil check
Just bought a super c with a manure bucket on it. How you check the hydraulic oil and how to add oil, when the port
where you add the oil, has a hydraulic hose connected there.
That hose should go to a resivor someplace and that would be where you add fluid. The C with a loader does not hold enough fluid to raise a loader thats why a hose should go to a tank or maybe the frame that uses the frame for a res. If the frame is used that way there will be a plug somewhere to add fluid.
