farmall 300 hydralic lines to fast hitch
dewy
where the bottom metal manifold line runs along trans cover,,it has rub slow leak whats best way to repair...thanks in advance.......dewy
I had a tubing shop bend up some bottom lines for my 300 a few years back and once he had the pattern setup I had him made some extra lines. You have to heat up the old line to unsolder it from the blocks at each end and then silver solder in the new line. If you are interested post back or send me a PM.
