Brad in VA
New User
Hello, just had a quick question. Been farming awhile but have run into a problem with one of my tractors. I bought a JD557 round baler in excellent shape recently, brought it home hooked it to the tractor and the door will only open about 1/2 way. With a little research I found that the baler requires 2,200psi to operate and my tractor I want to round bale with is a IH 656 Hydro diesel and it only has 1,900psi. So my question is what is the best way to increase the psi on my hydraulic system? I have read that you can replace the hydraulic pressure valve with one out of a 1086 for instance that will up the pressure but I have also heard there are some after market conversion kits that will up the pressure. Any thoughts would be appreciated thanks and God bless
