Super m hydraulics
dgoodman2
The auxiliary hydraulic valve on super m will leak
down pretty quick. Took it apart. Is there anything
that can be done to restore some of the tolerances
in it.
Also anyone have a parts diagram of hydraulic
reservoir and valves under gas tank.
Thanks.
Put Messicks farm equipment in search box, then click case, then put Super M in model search box, click on SM or SMTA. Click on hydraulic, Click on number 372.
Good hydraulic shop can renew piston and bore clearance in the remote control valve. Another way to make sure they don't drop is plumb in a check block from a fast hitch tractor. Using the remote control valve on this tractor with old rusted out tubing end end from a 400 and a check block.
