Super M Hydraulics
dgoodman2
Looking for parts. I have disassembled the entire hydraulic reservoir on super m. My lever would kick out with almost no load so I removed unit to find check valve. Does someone sell a kit for these or a supplier of 4 springs and balls?
Any other ideas appreciated.
Thanks.
I never saw a kit as we replaced individual parts as needed. All balls and seats should be available at CaseIH dealer. By kicking off, if you mean lever kicked back to neutral, that is the relief valve function to do that and if below 1200 psi, the relief valve would be leaking. Ball, seat and gasket under seat of relief valve.
Does anyone have any specifications or tolerances on these springs or balls so that I could know which ones to replace while I have it open.
And why does it not have a mesh filter like other tractors.
