Belly mower.........Farmall H
Every now & then you see an H on here with a belly mower. Don't know any details, but it sure seems like you'd want lots of space to operate it.
Glenn F.
finding the decks is easy but the mounts for an H is almost impossible unless you get a new one from Woods. If you do find a deck get a 6ft one if you are going to use it on an H the wider the better
Just bought one last week, 6' Woods, have to work on the tractor a little, needs some wiring work and the tires are round and hold air and that's about it.
Will try to post pic when I get home.
Here's my newest toy.
Woods L59-U or a L306-U. The 306 is wider. You can still buy new, but around $3000. It is a finish mower. The pulley mounts on the PTO shaft. Fairly complicated install, so once on you probably would not take it off.
I have a 1950 H with Artsway 6ft and it turns on a dime,but I put p.steering on it. Works good for me but is hard to get mowing highth adjusted just right.
I too have an H and looking at an L306 for it. I am in need of the mounting brackets and drive for it though, Any leads on those parts, a parts list, or even a picture of them would be greatly appreciated.
