Replacing amp gauge question
300guy
I have ordered a new Rockwell amp gauge for the 300, so my question is when I put it in, will I have to polarize the generator again since I will disconnect the battery? If I remember correctly, I will just touch the BAT. terminal on the regulator to the ARM. terminal with a jumper wire to polarize the generator.
The reason I ask this, is I have put in a new batteries before and never polarized the system after putting them in.
Not sure what a "Rockwell" Amp gauge is but polarizing the generator isn't needed unless the machine has sat a LONG while without being started OR the generator as been taken apart and OH'ed/dropped/abused.
On the other hand, polarizing (if done correctly) isn't gonna hurt anything!
AS typical, Bob and I agree. It's the Generator that gets polarized and replacing an ammeter shouldn't affect that. As long as the Cutout Relay (if stand alone or inside a VR) is working, when you shut the tractor down the gennys ARM post is disconnected from the ammeter and battery anyway.
John T
Rockwell is one made in the USA, has the IH symbol and is suppose to be the manufacturer of the original gauges.
I bet it's Rochester not Rockwell.
Yeah, sorry it is a Rochester gauge. I friend of mine said to get this one and I thought it was a Rockwell. My mistake.
