Farmall Super A Reserve Fuel
majikfish
Does the Super A have a reserve fuel supply? My tank never seems to run anywhere close to dry. If it has reserve, how do you access it?
NO reserve, some sediment bowls have a "riser tube" that extends upward a bit to take in gas above a little water, rust and debris rolling around on the bottom of the tank.
The only reserve SA had was when it did have two tanks small one for gas and he regular big one for distillate fuel sort of like Kerosene engine started on gas then when was switched to the Kero which was a cheaper fuel. Small tank was on the right side under the hood located above the filter only held a gallon or so as you didnt run on gas very long before switching That system was an option till in the middle 50s almost all tractors had a similar system as the Keo was much cheaper.
